wincc flex runtime problem
According to F1, you have a Graphic IO field without a picture corresponding to the current linked tag value.
Meaning, you use a graphic IO-field. In said IO-field you configure pictures for the values of the tag linked to it, like you do in a text list. But here using the Graphics list.
Getting the cacti/cactuses means that the tag is either 0, or more then 1 bit is set (if using bit number) or there isn't a picture configured for the current value of said tag.
If it's a static image, please use the Graphics View.
Edit: If it needs to be a dynamic image, then in the Graphics list, select one of the pictures as the default picture. That's another way to avoid getting the cacti/cactuses.
according to f1, you have a graphic io field without a picture corresponding to the current linked tag value.
Meaning, you use a graphic io-field. In said io-field you configure pictures for the values of the tag linked to it, like you do in a text list. But here using the graphics list.
If it's a static image, please use the graphics view.
Edit: If it needs to be a dynamic image, then in the graphics list, select one of the pictures as the default picture. That's another way to avoid getting the cacti/cactuses.
Hmm, the only other way I can manage to get it, using a graphics view, is when it's out of bounds. When I get the message:
Warning: Location or size of screen object is invalid.
Could be it doesn't like the picture, is it jpg, bmp, gif? Did you try deleting it, doing a Rebuild all, inserting again, Rebuild all?
Okay
Deleted the graphic view, made a new one, same graphic.
Rebuild All.
Okay now.
Thanks jeebs !!
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,682
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,244
Hello Experts, I have a problem in WinCC Flex 2008 Sp3, when I start runtime system , after 2 to 5 sec when it started to communicate with the...
1,710
I have a Siemens project with 2 HMI screens, one is a KTP600 Basic and the other is a MP 277 10inch touch. When I fire up the runtime from within...
4,455
Hello everyone, Info: I am using WinCC Flexible Runtime to log data to a SQL server. It is set up to log production values every minute from...
20
11,351
