WinCC Flexible. Need Active-X to view a Image.
smcmanus
Jan 2006
Vancouver
109
I need a simple Active-X Control to diplay an Image on my screen from a file on my hard drive. Any suggestion where I can get one. I thought WinCC would of had one. Thanks.
PS. I need the image to update when the picture updates!
I have used the active x controls from microsoft before, but in GE fanuc - Cimplicity. There should be a image control available. If these controls are not available on the PC/Panel, the microsoft ActiveX control pad can be installed.
Ok maybe I posted a little quick. What is Microsoft ActiveX Control Pad and how would I use it with WinCC flexible?
I have done some playing with Active X controls and WinCC Flexible but I have never needed to use one for a project. Im sure one day it will come up. I would love to see what you come up with for the image update.
Hey Charles. What I did end up doing is using the HTML Web Browser to view the picture on the local disk. I used the HTMLBrowser Activate Event to run the HTMLBrowserRefresh under Keyboard Operations for Screen Objects. Now to refresh this brower I have a tag that on change of value runs a script.
Dim object
Set object = HmiRuntime.Screens("Screen_1").ScreenItems("HTML BROWSER_1")
object.Activate
We use Siemens WinCC flexible 2007 for HMI. In the HMI in one screen when one object pressed a faceplate open. In the faceplate many object there...
1,857
Hi here! People pls help me. I have one project with only one screen, made 2 scripts - 1 script writes in *.csv file time of the begining project...
2,709
I need a simple Active-X Control to diplay an Image on my screen from a file on my hard drive. Any suggestion where I can get one. I thought WinCC...
2,722
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
325
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
121
