WinCC flexible Question - need reply please
arocon
Oct 2006
Dubai
171
We use Siemens WinCC flexible 2007 for HMI. In the HMI in one screen when one object pressed a faceplate open. In the faceplate many object there . So it cover almost half of right side screen. Our Manager want the pop up(face plate) to be displayed on the left side.
My question is how to change position of the display of the faceplate ?
I have checked internet and manual and not getting any thing .
Your reply will be great help.
In engineering mode: Try to open the mother picture and activate all 'levels'. If you're lucky, the 'popup' might show up.
Kalle
you need to use wincc felxiable and active the faceplate you needed and than rebuilt it for
runtime ..
The line in scripts is if SmartTags("Enable\En_Maint_Enable") Then set Bit SmartTags("En_Open"); I did not understand what is the meaning of...
1,650
We use WinCC flexible 2007 for HMI. There are 3 HMI . One is in the pulpit and the other twos are in local. From local it has ability to jog and...
1,884
Could anybody tell me how these alarms got data (attached alarm). I have highlighted alarm no 1521 for example. The Trigger tag for this alarm is...
2,712
I have attached here two screen shot. The Local button Animation --- visibility is set as tag EN_LSTN_SPO. But this tag is internal tag. In this...
2,226
Attached screen from WinCC flexible Project. Could anyone please tell me how this Button Enable Object work ? Enable Object is not highlighted...
2,738
