WinCC Flexible question
arocon
Oct 2006
Dubai
171
The line in scripts is
if SmartTags("Enable\En_Maint_Enable") Then
set Bit SmartTags("En_Open");
I did not understand what is the meaning of the SmartTags("Enable\En_Maint_Enable") : Could anyone please explain me ?
Hello in the tag list En_Maint_Enable tag is there. But i could not find out where is the origin. Could you please tell me how to find it ?
The properties of the tag should tell you which physical connection, and what memory area (M or DB) and an address. Alternatively, it could be listed as in internal tag, in which case, it may be set by a script or a button on the screen. I think that you should be able to do a cross reference of the tag by right clicking on it but I'm not certain.
Nick
We use Siemens WinCC flexible 2007 for HMI. In the HMI in one screen when one object pressed a faceplate open. In the faceplate many object there...
1,850
We use WinCC flexible 2007 for HMI. There are 3 HMI . One is in the pulpit and the other twos are in local. From local it has ability to jog and...
1,884
Could anybody tell me how these alarms got data (attached alarm). I have highlighted alarm no 1521 for example. The Trigger tag for this alarm is...
2,710
I have attached here two screen shot. The Local button Animation --- visibility is set as tag EN_LSTN_SPO. But this tag is internal tag. In this...
2,226
Attached screen from WinCC flexible Project. Could anyone please tell me how this Button Enable Object work ? Enable Object is not highlighted...
2,738
