WinCC flexible question
arocon
Oct 2006
Dubai
171
We use WinCC flexible 2007 for HMI. There are 3 HMI . One is in the pulpit and the other twos are in local. From local it has ability to jog and but from pulpit no ability to jog. I need to do provide jog ability from pulpit HMI too. To do Jog you have to go maintenance mode and it needs login. After login only it can do jogging from local HMI.
I am looking to WinCC project to find out how to do it but could not able success it. I think it is in the script file . I have changed it but not successful.
Could anyone please give some suggestion where to look at it or how to do it ? I can not attached here project because it is too big.
You need to consider why there is no JOG function from the pulpit HMI. If the original machine manufacturer made the jog function on the local HMIs but not the pulpit, is it because it would be dangerous to JOG the machine from the pulpit? Have you asked the machine manufacturer?
Post the script. What error do you get?
Nick
We use Siemens WinCC flexible 2007 for HMI. In the HMI in one screen when one object pressed a faceplate open. In the faceplate many object there...
1,852
The line in scripts is if SmartTags("Enable\En_Maint_Enable") Then set Bit SmartTags("En_Open"); I did not understand what is the meaning of...
1,650
Could anybody tell me how these alarms got data (attached alarm). I have highlighted alarm no 1521 for example. The Trigger tag for this alarm is...
2,714
I have attached here two screen shot. The Local button Animation --- visibility is set as tag EN_LSTN_SPO. But this tag is internal tag. In this...
2,228
Attached screen from WinCC flexible Project. Could anyone please tell me how this Button Enable Object work ? Enable Object is not highlighted...
2,738
