WinCC flexible Question
arocon
Oct 2006
Dubai
171
I have attached here two screen shot. The Local button Animation --- visibility is set as tag EN_LSTN_SPO. But this tag is internal tag. In this tag properties change value Event 2 script will run you can see from attached.
My question is as it is internal tag how visibility get the value. Thank you.
it gets value same as external tag. for bool action logic it doesn't matter if the tag is internal or external. internal tag in wincc is like markers in plc.
We use Siemens WinCC flexible 2007 for HMI. In the HMI in one screen when one object pressed a faceplate open. In the faceplate many object there...
1,852
The line in scripts is if SmartTags("Enable\En_Maint_Enable") Then set Bit SmartTags("En_Open"); I did not understand what is the meaning of...
1,650
We use WinCC flexible 2007 for HMI. There are 3 HMI . One is in the pulpit and the other twos are in local. From local it has ability to jog and...
1,884
Could anybody tell me how these alarms got data (attached alarm). I have highlighted alarm no 1521 for example. The Trigger tag for this alarm is...
2,712
Attached screen from WinCC flexible Project. Could anyone please tell me how this Button Enable Object work ? Enable Object is not highlighted...
2,738
