wincc hmi connect to Omrom c200he
ajay34
May 2010
klang
249
hello all....
i been working with wincc HMI which connect to Omron PLC ch200he..
i facing a problem that ..i cant connect more than 1 HMI to omron using
protocol as on wincc (rs232) ..only way is to close 1 HMI and Open the other HMI ..
is there any confugation i missed or need to at any device in order make all my 3 HMI is working at Omron PLC same time ..
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
72
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
309
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
759
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,081
Hi I'm trying to display a value on the HMI. In monitor mode on the code, I can see that value, but on the HMI , after downloading, it is...
951
