I saw that to, JesperMP, but it isn't clear enough for me. This is sentence from that web page:
"In addition to using the WinCC/Redundancy option for running two servers in parallel, it is possible in a WinCC application to also implement redundant communication channels to the SIMATIC S7 controller. You do this by installing two communication modules and implementing duplicate communication paths (communication software S7-REDCONNECT needed). By using H-series SIMATIC S7 controllers, you can, if required, additionally increase availability at the control level. By combining system solutions, you can create a security concept that meets even the most demanding requirements."
First, this is explanation just for 2 servers, but could I get one or two more, if I had to;
Second, do I have to use some additional modules or just some additional software, like they mentioned S7-REDCONNECT, and is that expensive.
Third, I saw somewhere that I need to use some module CP 343-1 Lean to put S7-300 on the ethernet, first, and then to connect to my switch where servers are.
I hope you understand my issue?
Greatings!
