WinCC tag from 1 plc to another
JOLTRON
Aug 2006
MI
692
Hello all, I was wondering how to go about having 2 plc's communicate thru my touch panel. I have a MP-270 touchpanel running WinCC flexible 2005 Advanced. The HMI has a connection to each but neither PLC to the other. Is it possible to have an Input turn on a tag for that connection than have this tag turn on another tag that is read from the second PLC. It seems like an easy idea but I'm stumped.
Thanks,
-Joel
I don't know how fast it would be but I think it would work. Take the first tag and on change set value of the other tag. It gets a little more complex with bits but words and ints should be easy.
"...written to...", surely? Or have we misunderstood you?
Ken
If the dataexchange between the two PLCs is critical, then maybe going over the HMI panel is not so smart. But CharlesM's suggestion should work in priciple.
Maybe it would be possible to setup a direct connection between the two PLCs.
What exactly are the PLCs (and CPs) ? What connection type ?
It's not very critical. The system contains (2) CPU 315's and an MP270. I was just trying to find a quick and easy way to find out if a prox is on, on the first system before motion occurs on the next.
I wrote a code in Wincc script to write values into server and I've assigned this code to a button. This program works fine Now I want to execute...
6,706
Hi all i am using STEP7 V5.5 SP2 HF4 & WINCC V7.0 SP3 on a 64bit PC with Win7 Ultimate I have : 1. One UDT block in STEP7 project (Figure UDT) 2...
3,667
Recently I work on a project where my customer has WinCC as HMI, and Siemens batch as backend, and they use APL as the interface for CM and EPH...
450
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
421
In some screens, the tags are not 'updated'. If then i look into the Tagmamangement: the values and quality codes are "???" (See picture in...
602
