WINCC tag-value is "???"
Greet
Aug 2003
Mol
58
In some screens, the tags are not 'updated'.
If then i look into the Tagmamangement: the values and quality codes are "???" (See picture in attachment)
If then I put a string in the comment (see red box): the values becomes good.
Any idea?
Is there hidden characters on end of tag name?
WinCC is polling tags only when necessary or if tag is logged.
It is possible that your screen has different tag than on tag editor so tags are never scanned.
When you make change to tag, it is maybe polled one time after saved.
Hello Everyone, Can somebody tell me how I can move a internal value ( word, int, float etc) to a external tag in C script or VBS or another...
2,016
Hello, I am using WinCC Flex 2005 and I want to configure a button. If you look at the picture below, on release of the button(which is named...
1,397
Dear sir, i have used wincc for scada. in that press left click event write script of settagbit and on release left click event write...
1,663
I am trying to write a script that will change an internal tag in the HMI. I am having no luck on getting this to work. Does anyone have any...
3,215
Dear All, I’m working with WinCC v6.0. I cannot set a negative tag value. If the value is >0, everything is OK. The value is a PID-control...
2,468
