WinCC tag import
ian.milling
Nov 2014
Newport
Having difficulties importing a CSV file into WinCC.
All the data from my CSV file is being populated in the first column(name)
Using tabas the seperator of the CSV. Have tried changing it to ; and putting a column of ; in the csv between the data ranges.
See attached Jpeg..... What am i doing wrong?
Make a tag export of the tag list with working tags.
Then compare the format with the format of the CSV file you are editing.
Use notepad for this comparison.
When importing a CSV file into Excel, Excel may do things to the file depending on many settings. Be sure to save in pure CSV format. Decline to let Excel "save formatting".
yeh thats what i ended up doing. The siemens converter tool doesn't put it into the correct format?
Ended up using the format from the export and copy/paste my addresses.
Recently I work on a project where my customer has WinCC as HMI, and Siemens batch as backend, and they use APL as the interface for CM and EPH...
450
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
422
In some screens, the tags are not 'updated'. If then i look into the Tagmamangement: the values and quality codes are "???" (See picture in...
604
Hello Everyone, Can somebody tell me how I can move a internal value ( word, int, float etc) to a external tag in C script or VBS or another...
2,031
Hello, I am using WinCC Flex 2005 and I want to configure a button. If you look at the picture below, on release of the button(which is named...
1,398
