WinCC V7.0 Tag Configuration Extraction
the_superfly5
Jul 2010
Orlando
Running WinCC v7.0. On an existing IFIX system, our management likes the feature of right-clicking on an I/O field in runtime and being able to access tag configuration information, i.e quick trends, I/O address, etc. We would like to maintain this functionality in our WinCC system. The IFIX feature is built in and is apparently not available in WinCC directly. I need to know if there is a way through VBS or C to capture this data and display it in runtime. Thanks
To make it look and feel the same would be near imposible but you could probably replicate the features if your prepared to put the effort in. It is posible, for example, to dynamicaly assign trends to a trend view via some script. If you had a trend view on screen you could program 4 drop down boxes with a list of available parameters to display. Having selected an item in the drop down box you can then assign it to a pen on your trend view.
Nick
Recently I work on a project where my customer has WinCC as HMI, and Siemens batch as backend, and they use APL as the interface for CM and EPH...
450
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
421
In some screens, the tags are not 'updated'. If then i look into the Tagmamangement: the values and quality codes are "???" (See picture in...
602
Hello Everyone, Can somebody tell me how I can move a internal value ( word, int, float etc) to a external tag in C script or VBS or another...
2,027
Hello, I am using WinCC Flex 2005 and I want to configure a button. If you look at the picture below, on release of the button(which is named...
1,398
