Windows XP embedded instead of Windows CE
Handcraftedsince87
May 2014
Washington
120
Im looking at buying a Maple HMI612H-001 HMI and am wanting to run the advanced HMI software. Im a little confused if I can make this work with the windows ce that is on the HMI Im looking to buy, or if its possible to load windows xp embedded instead on the maple HMI. I didn't have any luck with my gugle-fu and was hoping someone could point me in the right direction. Thanks in advance
Dan
You want to try to get a Windows 7 machine if possible. AdvancedHMI will not run on Windows CE. Currently AdvancedHMI is based on .NET 4.0, but future versions may be based on .NET 4.5 which is not compatible with XP.
I run everything on Windows 7 Professional. I usually recommend IVC displays, but we are in the process of selling fully configured and tested systems for AdvancedHMI on the web site.
Hi, on some PCs that we use at customer locations and that are running non-critical programs, and are running with 'normal' Windows i.e. not Win 7...
1,937
Hi and hope all is well. We are starting up a used machine that came from France. We installed 480 delta to 400 vac wye transformer. When we...
2,835
Hi All I am trying to update my communication driver for PLC/HMI communication via DH+ to ethernet/IP. I have an automation PC that is running...
3,125
Good Friday. I have a Generic Panel 7" that Runs on Windows Embedded CE 6.0 I am curious if there is an HMI Software that I could use with this. I...
2,748
I like to install a VNC server on a controller with Windows Embedded Standard 7. The controller is a Beckhoff CX20x0-0122 and probably will use...
5,070
