Wire..... any electrical suppliers out there?
geniusintraining
Jun 2005
SC
8,277
Hello Everyone,
Looking for a special wire that I can not find anywhere, has anyone seen this or know where I can get it?
Looks like a 18 or 20 gauge, it will be less then one amp and 24VDC its a two conductor wire both are covered with a clear PVC, looks almost like a single conductor with a shield but using the shield as a conductor
Thanks for looking!
git, is that a cable with 2 wires individually screened, or a cable with a single screened wire ?
The Belden 8760 has common screen for 2 wires so it is neither of the above.
Sometimes single wire with screen is called "RG coaxial" and is for transmitting high frequency signals.
Cable with a single screened wire
Its one wire thats coated with clear PVC then that wire is screened (shielded) by the outer wire and that is also coated with the clear PVC, so like I said... its like a single conductor with a shield :confused:
I have never came across it before and now I need a few hundred feet, one of the issues is it need to be the same diameter
I checked the 8760 and that was not the one but thanks for the suggestion
Thanks Bob, that looks like it (or close) but now I need to find it in clear... I will call them later to see if they can get it, the customer wants clear like the picture and I told them "oh yeah thats not a problem" ;)
Never thought finding a wire would be a issue
I searched Helukabel (the biggest supplier I know) for a coaxial cable with clear mantle and clear inner separator. No such luck.
Thank you! I sent a email to Alpha Wire and I will see if they can come up with anything
Is it possible for AutoCad Electrical to generate wire lengths, if e.g. paried with a 3D assembly from Inventor with matching part numbers? This...
2,718
Hi, Have a job where the client spec calls for their own style of wire numbering. They want unique identification each end of the wire using the...
18
8,335
i am building my first control panel and also doing the design and schematics using autocade 2006 . i am using a line reference based wire...
20
21,851
Hi guys, I've got probles in color on the PLC terminals. what color should be on the low voltage wires? Blue on both positive and negative? and...
20,334
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
271
