Wireless RS-232
jrjames
Apr 2003
Malta
Hi all,
Can anyone help me source a company that provides a wireless link to transmit RS-232 data from a PLC to my service PC.
We have a number of machines with mostly Siemens or ABB PLC's. I connect to these via a serial port on my laptop (the Siemens via the PC-current loop converter).
The PLC cabinets are not near the machines, so I cannot check the status whilst on the machine, without great trailing lengths of cable!
I would like to find a transmitter/receiver pair that will transmitt the serial info from the PLS to my laptop.
Any ideas?
The link above came up in German and I couldn't find an alternate language button.
Here's the US web page for the same Phoenix Contact radios I've used.
http://www.phoenixcon.com/wireless/detail.asp?l0=WIRELESS&ProdGroup=29&l1=Wireless+Data
2nd from the top. You need two, one for each end, and and an antenna for each. The short 1/4 wave antenna should work fine for within a site.
There are issues about frequency allocations that vary from country to country, so you need one that's legal whereever it ends up.
Dan
DeviceMaster AIR
I'm not sure if you've seen the DeviceMaster AIR or not, it's a flexible, wired, or wireless 802.11b to RS-232/422/485 device.
If interested, feel free to contact me for a 60-day free evaluation.
Maxstream makes some RS-232 radios that I have messed around with, they have pretty good range and you can run them off a 9-Volt battery, not sure how long you can do that for but you can do it.
Alternatively if you have an ethernet connection you can connect an access point to it temporarily and use ethernet to communicate. Assuming of course that the software and PLC support ethernet communications.
Hi all. I work in food processing plant and for the last 18 months have been fighting with production over scales being put away and bagging of...
2,778
hello all... i was facing some issue rergading cable ( com cable between scada and PLC) always beaten by Rat (roden)..even had call pest control...
2,540
We're working on a job that we're installing an RFID security system on the elevators and latter possably on 9 door strikes. This is the...
4,200
Hello Guys! I have a problem with a wireless-bluetooth communication between a plc and a panel (if I use a rs232 cable the communication works...
4,045
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,376
