r232 wireless to PLC (OMron)
ajay34
May 2010
klang
249
hello all...
i was facing some issue rergading cable ( com cable between scada and PLC)
always beaten by Rat (roden)..even had call pest control to solve but unable
even had protect it in conduit but it always find way bite it .
i was thinking to use wireless device which able to connect between scada and plc ..by replacing cable's..
example fix wireless r232 serial port transmitter at pc (HMI)
and fix recevier r232 at PLC ( say model c200he) port..
estimate about 40mtr..
would it work ? or a`1 had try this ?
I have used wireless bridges to connect a PLC to a plant network and also between two PLCs in separate buildings. I don't see any reason why that wouldn't work between the PLC and HMI with the right equipment.
Hallo, I have Tia Portal V16 and I'm upgrading an older machine. That machine has a component running on rs232. The machine has still the old...
952
Has anyone connected their IDEC PLC with a usb-rs232 adaptor? Which adapters work and which don't? Thanks
1,678
guys.. does any1 know how too convert rs232 cable to usb for plc as unitronics,seimens mitshubhisi and allen bradely
2,444
hi, i was wondering anyone can help me how to configure for Melsoft GX-Developerusing a USB to RS232 cable converter as my current computer does...
7,257
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,348
