Wiring two open collector outputs to 1756-IB32 input
guitarwiz23
May 2016
Louisiana
I am trying to wire a device which has 2 separate open collector outputs that need isolated channels to function properly to a 1756-ib32 discrete input card. The 24V from the power supply is not grounded. The way I am thinking this could be set up is:
+24V to the coil of 2 individual relays -> from the coil of the relays to the collector of each output, and from the collector of each output back to the 24 common/return. Then the plc is wired to the common and normally open of the relay contacts.
The part I am concerned with and would like feedback on is whether the emitter of the open collector output should be taken to common or to ground.
Thanks in advance for any input
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
140
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
87
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
157
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
118
Hello I wanted to ask some questions about the G120C drive and the protection for it. I want to control a pump, with the motor rating of 5.5 kW...
207
