Wonderware Historian data to Excel Format
Apr 2011
Manila, Philippines
295
Good Day,
Is it possible to convert Historian data files into Excel Format?
I am pertaining to Historian data files that are located within Cicular Folder.
Can I just paste all these folders to the Circular Folder of a newly-configured Historian?
I attached some screenshots for reference.
Thank you for the replies.
You can view the tags you want in the trend/query tools, the export/save the data.
I don't know of a way to convert the circular blocks to CSV, you could do it via SQL maybe...
You should be able to copy the blocks to the new historian if the configuration is the same...
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
187
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,587
Hello there, Our plant is running Wonderware Historian on a Virtual Server and every few days I'm losing comms to my PLCs. Usually I can simply...
2,076
Hi all, I found some interesting issue from my Wonderware environment. At my Trend table option, if i select "both", the Trend table is not...
3,668
Hello, I want to monitor Wonderware historian's heartbeat and trigger a fault if Historian is not communicating /offline in PLC. Currently my...
798
