Wonderware Historian Extension table
mony9909
Apr 2022
United Kingdom
Hi all,
I found some interesting issue from my Wonderware environment. At my Trend table option, if i select "both", the Trend table is not showing anything. But when i select "Extension table", the Trend table is working perfectly.
I just want to know why, because option "both" should retrieve data from both the manual and extension table.
Please find the attached table for your reference.
I have seen this when the Historian RUNTIME database's SQL collation does not exactly match the SQL server collation. This causes issues when the UNION statement tries to combine the data.
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
176
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,557
Hello there, Our plant is running Wonderware Historian on a Virtual Server and every few days I'm losing comms to my PLCs. Usually I can simply...
2,072
Hello, I want to monitor Wonderware historian's heartbeat and trigger a fault if Historian is not communicating /offline in PLC. Currently my...
790
Any of the WW gurus know if it is possible to extract and alarm log from the historian in Wonderware. Were using WonderWare Historian 2017. I...
7,165
