Wonderware Import Tags Help
SpecialK87
Sep 2018
Missouri
49
I am using WonderWare InTouch Machine Edition and when I tried to do a tag integration, it did not import my AOI or UDT tags from RSLogix5000. Does anyone know why this would be?
I don't have much experience with WW so any help is much appreciated. Thanks
Kyle
Thank you but as far as I can tell this doesn't apply to InTouch Machine Edition. However I may be missing something.
My understanding is that the UDTs should create "Classes" in the WW program, all of the members should be found in the Class. I do not have any Classes imported. However, I can find the base tag(not sure if it's called that) such as "From_HMI_Hoist_VFD_NorthSouth.Manual_PB" but anything after the "." I cannot find.
Odd behavior from Wonderware when I imported a couple windows. All the tags used on the windows already existed, but all of the tags came in with...
1,427
Can anyone please say if we can import tags for scada from excel to wonderware?? I have created tags of SCADA objects. I need to name each object...
8,005
I am very 'green' with Wonderware... What it the easiest way to import tags from RS5000 to Wonderware V9. I exported both tag lists to CSV files...
5,222
So I'm working on a system with Step7 5.5 running on a couple of 300's. They have Wonderware as the HMI. They have servers and clinets and an Eng...
1,399
I have Wonderware Archestra Backup.How I can Import It?
2,805
