Wonderware Intouch 9.5.100 Viewer Crashing
Grendizer
Apr 2012
Toronto
88
Hey All,
I just started to have this issue with Intouch Viewer. When I start Viewer, it works normally, then, after x amount of time, Viewer Disappears! It is running, but I can't see it. When I try to close Intouch Maker and reopen it, it says that Viewer is running. Any ideas of what's going on?
Btw, I restarted the computer few times and still the same issue.
Thanks all,
Are you doing any historical logging? If so, delete or rename the last days*.lgh and *.lgx files. I've had an issue where these become corrupted and will crash WindowViewer.
Depends, it's in your configuration. Open up WindowMaker, in the configure menu there is a selection for "Historical Logging". The path for your log files is specified there.
Ok, I backed up and delete the old once.
After crashing and restarting the computer for around 10 times, the problem seems to go away. Intouch fails again..
Hey All, I am having this strange problem. It is so weird that I did not know what the title of this form should be. I have a "AlmDbViewCtrl"...
2,843
Hey all, Is there a way of checking if a tag exist in the Database through scripting? Like maybe a function that check for tag existence? Thanks,
1,492
Hey all, Is there a trick of opening a multiple instances of the same window? For example, I have 5 buttons that open the same common pop-up 5...
3,163
Hey All, Is there a way of dumping tags associated to a specific screen? For example, I have screens x, y and Z and I want to dump ONLY the tags...
3,921
Hey all, Am trying to rename tags, thousands of them, without having to open the "Tag Dictionary" and modify them from there. Is there a way of...
21
17,925
