Wonderware intouch support required
Jul 2012
dxb
good day to all.
support is required in SCADA wonderware intouch, kindly before reading download attached pictures and excel sheet.
I want to make an excel sheet database as attached sample, and a window -as attached "PIC1" in which i can insert and save 2 text boxes meanwhile saving them to excel sheet, and any new data entry to be take the next vacant row in the excel file
meanwhile in "Pic2" when entering a saved material name, it is required to retrieve the equivalent material name and codes from the excel file.
Please support to achieve the same purpose noting that i'm using Intouch 9.5
many thanks
InTouch have an add-on for this - 'Recipe Manager'
It should be on your install disk.
Krk,
your input is good, but is this a separate package of wonderware?
i'm not able to find this add-on in script function, see attachments
Hello, I am working on a project under Schneider M580, We have an existing supervision PC station develloped with Wonderware Intouch. The...
962
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
172
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
173
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
440
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
208
