Wonderware Intouch Value Format
DzakwanAfif
Mar 2019
Bandung
Hello, I just need some help here...
I integrate my PLC and HMI through the KepserverEX (OPC). When I check at the OPC quick client, I see that the flow through the pipe is 2.6 m3/Hr.
But when I check at the HMI, it just sends me 3 m3/hr (the intouch make my value increment to 3 m3/hr).
Does anyone know how to fix this? So the value in the Intouch HMI is the same as in my OPC Quick Client.
For another information, the tags I declare is already at IO Real type.
Thank you so much:geek:
Try right-click on the text and choose substitute strings. Change ## to ##.# or however many decimal places you want to see.
hi there, I have a tag in which is stored realtime value of voltage. I'm need a way to record a maximuum value of this voltage and dispay it on...
4,012
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
164
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
172
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
434
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
204
