Wonderware Modbus
Dilbert
Guest
D
People,
I want to have data (Modbus holding registers ) in WW Intouch 8.0 from an old PLC whic can communicate on Modbus. Can I have a list of essentials?
I mean which Modbus driver, I/O server I require to install in WW? where I can find it?
There is no mention of Port, Parity, baud rate in WW Access Configuration? Is that Only available after driver installation?
I could communicate the WW with RS 5K emulator on single PC through DDE.So I can say that I know normal settings but never done actual communiaction with the hardware with WW.
Please enlighten me.
In a Nutshell:
The Modbus driver is on the I/O Server (Driver) CD.
Once installed, run it and then define a Topic and all the comm. parameter stuff.
For your tag, make it an I/O Integer type (not memory) , click Access Names, the Add a new one, with the Application name being the I/O driver, and the Topic name the same one you created in the I/O driver. You can define your own Access Name, I make it the same as the I/O driver's Topic. Put the holding register address in the Item field.
That should do it. This is all from memory and a quick look at a WW app that DIDN'T have a I/O driver used (was using DDE) so If I've missed a step here, forgive me.
Use the help file included with I/O driver and see the general help file for Access Names.
Hello, I am attempting to add some IO Discrete tags to a AVEVA InTouch project (version 2020). These tags use the MBTCP driver and attempt to map...
1,211
So I am trying to access data from an Eaton PXG900 Power gateway with Wonderware. The gateway can be polled for data by Modscan and does provide...
2,874
I'm creating a new HMI to communicate with a Yaskawa controller. I started adding some of the values to the screen from the 4XXXXX registers and...
2,439
Hello I'm trying to read a register from a Modbus device into Wonderware System Platform. In object viewer it shows the status of being "Good"...
1,928
I about to upgrade all of my computers in the plant to windows 7 machines. My problem is that some of them are running Wonderware with Modbus Plus...
1,466
