Wonderware Support/Upgrade Policy?
harryting
May 2002
Puget Sound
2,595
Here's the scoop, there used to be a WW installation here a long long time ago. The program and the software itself has long been lost. All I got is a WW "key serial number" and an Intouch 4.0 "PEC" code.
Anyone know off hand what WW policy on possibly upgrade an out of support software is?
being direct to the point ww will sell you an entire software package,upgrades for a version that old isn't gonna happen. your best bet would be to check at hmi/scada vendors and compare what you need for i/o tags and purchase a new package based on your needs and budget.
It would be worth your time to check with your Wonderware distributor. InTouch 9.5 is out and they are offering (as they always do) a discount up to 50% on upgrades. Although you are using a fairly old version, so I wouldn’t expect a 50% discount.
You should also know that you can save some money on InTouch licenses if you already have or purchase your own IO server. You can order an InTouch license without an IO server license.
Also depending on your set-up, you might be better off going with InTouch for Terminal Services. This will allow you to purchase runtime licenses for the maximum number of concurrent users using the system as apposed to the number of computers InTouch is installed on.
Hello, I am working on a project under Schneider M580, We have an existing supervision PC station develloped with Wonderware Intouch. The...
959
Hi everyone! My first post, so any advice appreciated! I am working with a setup involving about 6 AB CompactLogix 5000 PLCs and 5 Wonderware HMI...
1,490
good day to all. support is required in SCADA wonderware intouch, kindly before reading download attached pictures and excel sheet. I want to...
2,894
Setting up a new Wonderware InTouch node in an existing enviroment and the machine IT sent me is running 2003 server. I have configured a dual...
5,840
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
155
