Wonderware tag edit
Apr 2011
Manila, Philippines
295
How can I edit a tag from being an I/O real into I/O Integer, considering that the tag was a member of a Super Tag?
I cant find an option to change it in tagname dictionary.
Thanks.
I believe some tags cannot change type once created. I think you can change a Memory integer to an IO Integer but not to a Real.
I think you have two choices:
If you delete all of the places in the code that use that tag, you can do an "update tag counts" (something like that) and then will be able to delete it and recreate it.
You can change the name of the tag and then create a new tag with the original name. I think you will still need to go through you code to replace the renamed tag with the new tag.
What I did is DB dump the tags, and in Excel (CSV ext) I deleted the tags that I want to edit. DB load it to my Back up file (no tags) then re-create new tag, this time with correct attributes. :)
Thanks for the reply Sir
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
215
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,615
Hi everyone! I am very new here (only a few hours old) but I am so glad this website exists. It has proved so useful already and I hope to be...
2,003
Having a Issue at a site where WOnderware can seemingly connect to the PLC and all shows good except its locked into a loop for downloading the...
1,829
Hi all, Has anyone here ever converted Wonderware tag history and added it to ignition's historical database? If so, how did you do it? Are...
2,438
