Wonderware to control logix comms
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am connecting a control logix l72 processor to a Intouch 2017. We want to use a OI gateway to connect to the plc through a Ethernet connection. what i am having trouble with is figuring out how to configure the gateway and the plc to facilitate these comms. Does anyone have an example of the configuration they can share with me so I can use that as a guide in our application? thank you for any help you can give.
How the time synchronization between the wonderware and Control logix is done.
3,821
Let’s say you were devolving a new program for a Control Logix Processor, and you knew this PLC would be monitored/controlled form a Wonderware...
4,046
Hello I upgraded an Wonderware InTouch computer that’s has cameras that can be viewed by clicking a button to view them. After digging into the...
2,247
I drag and drop them (valves, pumps, etc.) onto the displays, enter the object name, and they update fine at runtime (turning green, etc.), but...
1,856
I operate a distillation column for Argon gas. It has a pressure controlling valve that cools a condenser at the top of the column with nitrogen...
2,274
