workstation and PC
shkoko2000
May 2011
cairo
296
dear all,
i want to know the main differences between workstation and pc specially at spantime.and can i use pc instead of workstation to operate rsview32 34hours as a scada system or must bring workstation
I don't know what spantime is.
Only you know how large the system is and how much workload it has so your question cannot be answered.
I would use a workstation for a SCADA system
spantime means life cycle of each device.and i need pc to work for a scada system
That depends on the manufacturer, so you need to ask them that.
As above, we use Workstations for SCADA systems but without knowing the size of yours its impossible to answer.
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
328
Hi, I am running a Windows 10 VM with Rockwell Studio 5000 on a Windows 10 host PC. I communicate to the PLC network through a USB-C to ethernet...
1,607
Hi guys, I am trying to use VMware workstation 16 player to configure RSlinx but have run in to all sorts of issues. 1. Not able to configure...
2,563
What is the main difference between the 2 licenses? I have a lot of experience with the Machine edition but not so much with the Server Edition...
4,150
I installed RSLinx Classic OEM 4.21 and tried to configure a Ethernet/IP driver on it, but in the RSWho window I cannot see the workstation or the...
1,853
