Write loaded application name to HMI tag
There is a registry key at HKEY_LOCAL_MACHINE\SOFTWARE\Rockwell Software\RSView Enterprise\3.0\Retentive\RDMCACHE that includes the most recently launched app name its value to handle the retentive tag data (ex: "\\Windows\\Logs\\<AppName>\\Retentive".
It still wouldn't be perfect, because it only gives the most recently launched (not loaded) app, but would be pretty close. Except I can't seem to read that key with the CIP message I was using to get the startup app. At least for the PanelView Plus 6 I am testing with, I came up with a total of 13 keys in the registry that are whitelisted to read - and that one's not in the list.
I'll stick with reading the startup app for now unless there's some other rock to look under.
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
98
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
139
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
162
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
133
Hello, This is my first exposure to CCW Micro8xx family. Someone will write to my existing micro850. Modbus TCP is turned on and I created a...
176
