Write RSView32 Data tags to SQL trough VBA code
May 2006
Monterrey
Hi, I dont have much expirience with VBA programing and I have an RSView32 Application that needs to write certain data to an SQL database, Im using MS SQL Server 2000, And the MS Visual Basic Editor integrated with RSView32.
Where can I find a VBA sample code on how to do this?
I just need to be able to access one Table (called Events) , this table has 5 elements (EventID, EventSourceID, EventTypeID, EventTime, ParentEvent) and I need to write values from 4 tags that i declared in RSview32.
e.g.
Tag_1 writes to EventSourceID (Int)
Tag_2 writes to EventTypeID (Int)
Tag_3 writes to EventTime (String)
Tag_4 writes to ParentEvent (Int)
Thanks!
Here is a sample RSView32 VB file, for data logging of 20 Tags. You will also need an EVE (Event) file or program to call this program periodically. I call it once a minute:
Public Sub WriteCSVLogFile()
Dim LIW_Flow_WY_100 As Tag
Dim DensitySP_FCV101_D As Tag
Dim EvapSP_FCV101_E As Tag
Dim MoistureSP_FCV101_M As Tag
Dim FlowSP_FCV101_L As Tag
Dim MagFlow_FT_101 As Tag
Dim Moisture_AT_103 As Tag
Dim Pressure_PT_106 As Tag
Dim Level_LT_117 As Tag
Dim LIW_Flow_WY_200 As Tag
Dim DensitySP_FCV201_D As Tag
Dim EvapSP_FCV201_E As Tag
Dim MoistureSP_FCV201_M As Tag
Dim FlowSP_FCV201_L As Tag
Dim MagFlow_FT_201 As Tag
Dim Moisture_AT_203 As Tag
Dim Density_DT_301 As Tag
Dim Temperature_TT_107 As Tag
Dim Temperature_TT_112 As Tag
Dim Temperature_TT_116 As Tag
Dim LogDate As Date
Dim OldLogDate As Date
Dim LogFile As Integer
Dim HeaderTrack As Integer
On Error GoTo catch
MkDir ("C:\POT_CARB_LOG")
Check:
'Check to see if the header needs to be inserted.
'HeaderTrack is an Integer bit that is set to 0 if it is Midnight, otherwise set = 1.
If ((Format$(Time, "hh:mm:ss") >= #12:00:00 AM#) And (Format$(Time, "hh:mm:ss") <= #12:01:00 AM#)) Then
HeaderTrack = 0
Else: HeaderTrack = 1
End If
Set LIW_Flow_WY_100 = gProject.TagDb("WY_100_SCALED")
Set DensitySP_FCV101_D = gProject.TagDb("FCV101_D")
Set EvapSP_FCV101_E = gProject.TagDb("FCV101_E")
Set MoistureSP_FCV101_M = gProject.TagDb("FCV101_M")
Set FlowSP_FCV101_L = gProject.TagDb("FCV101_L")
Set MagFlow_FT_101 = gProject.TagDb("FT_101_SCALED")
Set Moisture_AT_103 = gProject.TagDb("AT_103_SCALED")
Set Pressure_PT_106 = gProject.TagDb("PT_106_SCALED")
Set Level_LT_117 = gProject.TagDb("LT_117_SCALED")
Set LIW_Flow_WY_200 = gProject.TagDb("POTCARB\WY_200_SCALED")
Set DensitySP_FCV201_D = gProject.TagDb("FCV201_D")
Set EvapSP_FCV201_E = gProject.TagDb("FCV201_E")
Set MoistureSP_FCV201_M = gProject.TagDb("FCV201_M")
Set FlowSP_FCV201_L = gProject.TagDb("FCV201_L")
Set MagFlow_FT_201 = gProject.TagDb("FT_201_SCALED")
Set Moisture_AT_203 = gProject.TagDb("AT_203_SCALED_IN")
Set Density_DT_301 = gProject.TagDb("DT_301_SCALED")
Set Temperature_TT_107 = gProject.TagDb("TT_107_SCALED")
Set Temperature_TT_112 = gProject.TagDb("TT_112_SCALED")
'Set LogDate equal to current date function.
LogDate = Date
'Get available file number
LogFile = FreeFile
'Open File for writing to and name file with form date.csv
Open "C:\POT_CARB_LOG\" & Format$(LogDate, "mmddyy") & ".csv" For Append As #LogFile
'Insert the Header into the csv file between 12:00 and 12:01 midnight and then insert the data in the correct columns.
If HeaderTrack = 0 Then
Print #LogFile, " Time"; ","; _
"WY-100_LossInWeight"; ","; _
"FCV101_D"; ","; _
"FCV101_E"; ","; _
"FCV101_M"; ","; _
"FCV101_L"; ","; _
"FT-101_Mag_Flow"; ","; _
"AT-103_Moisture"; ","; _
"PT-106_Pressure"; ","; _
"LT-117_Level"; ","; _
"WY-200_LossInWeight"; ","; _
"FCV201_D"; ","; _
"FCV201_E"; ","; _
"FCV201_M"; ","; _
"FCV201_L"; ","; _
"FT-201_Mag_Flow"; ","; _
"AT-203_Moisture"; ","; _
"DT_301_Density"; ","; _
"TT-107_Temp"; ","; _
"TT_112_Temp"; ","
'Insert data into column if the header was just inserted
Print #LogFile, Format$(Time, "hh:mm:ss"); ","; _
Format(LIW_Flow_WY_100.Value, "##0.00"); ","; _
Format(DensitySP_FCV101_D.Value, "##0.00"); ","; _
Format(EvapSP_FCV101_E.Value, "##0.00"); ","; _
Format(MoistureSP_FCV101_M.Value, "##0.00"); ","; _
Format(FlowSP_FCV101_L.Value, "##0.00"); ","; _
Format(MagFlow_FT_101.Value, "##0.00"); ","; _
Format(Moisture_AT_103.Value, "##0.00"); ","; _
Format(Pressure_PT_106.Value, "##0.00"); ","; _
Format(Level_LT_117.Value, "##0.00"); ","; _
Format(LIW_Flow_WY_200.Value, "##0.00"); ","; _
Format(DensitySP_FCV201_D.Value, "##0.00"); ","; _
Format(EvapSP_FCV201_E.Value, "##0.00"); ","; _
Format(MoistureSP_FCV201_M.Value, "##0.00"); ","; _
Format(FlowSP_FCV201_L.Value, "##0.00"); ","; _
Format(MagFlow_FT_201.Value, "##0.00"); ","; _
Format(Moisture_AT_203.Value, "##0.00"); ","; _
Format(Density_DT_301.Value, "##0.00"); ","; _
Format(Temperature_TT_107.Value, "##0"); ","; _
Format(Temperature_TT_112.Value, "##0"); ","
Else
'If time anything other than 12:00 and 12:01 midnight just insert the data
End If
Close #LogFile
'If the directory already exists, skip to the next line
'Error 75 is directory already created or exists.
catch: 'Error handling routine
If Err.Number = 75 Then
Err.Clear
GoTo Check
Else:
If Err.Number = 4170 Then
Print "Error#4170--Communications driver is not available."
'roErrorTagEvent (4170) - an error occurred while waiting for the operation to complete
Err.Clear
GoTo Check
End If 'End errror #4170
Err.Clear
End If 'End errror handling
OldLogDate = LogDate
End Sub
PLC Experts, I have written an RSView32 application that generates a CSV file based on a trigger from the PLC. Each day a new file is created...
3,391
I am having issues writing to micrologix 1100 from RSView 32 I am communicating through ETHERNET/IP and can see the plc data and can do a...
5,556
Hi All, Currently I am networking several PLCs together (SLC5/04, SLC5/05, ML1500) and used RSView32 to create real time visual manufacturing...
7,288
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
102
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
141
