XIO/XIC vs. NO/NC
XIC (or the corresponding symbol, regardless of brand) is an INSTRUCTION, not a contact. It instructs the processor to check the state of a bit in memory - looking for a 'one'. When I was learning PLC, I actually taught myself to refer to the XIC as the "look for a one" instruction.
XIO is therefor the "look for a zero" instruction.
For folks that INSIST on referring to these 2 instructions as "normally open" and "normally closed", have them draw the ladder logic to "seal in" an output instruction, with a normally open start button and a normally closed stop button.
That single example should break them of the habit and provide the ultimate "aha!" moment.
This is funny, but I spoke today with a guy who just completed a PLC course. When I asked if instructors emphasized that NO ≠ XIC, and NC ≠ XIO, he said no. It's pretty sad, as this is when problems start. If people are aware that NO ≠ XIC, then they will eventually figure it out, but if they aren't even told this, they almost certainly will have a lot of confusion later on.
It IS sad, and one of my pet peeves when it comes to typical plc instructors.
As far as I know all the standards (IEC, etc) call them normally open and normally closed.
I'm not sure how the latching example proves your point? The normally open / normally closed naming doesn't have anything to do with the physical wiring. If you want to mirror the input you use NO, if you want to invert it, you use NC. Exactly like an actual relay.
iLuh2c2wUai8x4y62
The NO/NC thought process is exactly why 80% of my students (experienced electricians) get this exercise wrong (until I teach ‘look for a 1 / look for a zero’.
(See linked image below)
For me it's NO = current/logic passing (in its default state) and NC = not current/logic passing (in its default state), whether in the real or virtual world.
Well you got that 100% wrong...
NO = Normally Open, in its default (normal) state, it is Open, so no current can "pass".
NC = Normally Closed, in its default (normal) state, it is Closed, so current can "pass".
I believe A-B did exactly the right thing calling their PLC instructions XIC and XIO, so as to alleviate the confusion that can be caused by NO and NC.
And it's not just physical inputs we are talking about, it works the same for internal bits.....
XIC = evaluate as "true" when the bit is TRUE
XIO = evaluate as "true" when the bit is FALSE
These instructions just pass rung logic continuity (true or false) to the next instruction in the logic....
Exactly!!!
There is no “power” or “current” in rings of ladder logic. Ladder logic is a programming language, checking 1’s and 0’s or changing 1’s and 0’s.
Just like Basic, or C++, or Fortran. Except ladder logic uses pictures to represent ‘if this, then that’.
Necropost alert
iLuh2c2wUai8x4y62
For me, thinking of the IO cards as interposing relays makes everything fall into place:
EDIT
I just remembered another PLC brand that has inverted output coils, just to confuse everyone even more xD
I am a beginner at RSLogix 5000 and in ladder logic in general. I am tasked with making sense of an existing program and reprogramming it to make...
6,053
Hi, I am using an AB PLC5. I have a rung with three branches on the right, so that it has three connections to the right (output) rail...
7,163
This is a long, double-post explanation of XIO and XIC. It goes through the full derivation of the concept and ultimately ends with a...
46
42,839
Hi, I am new to plc and i was reading the contensts in plcs.net. I have a doubt. i am not able to understand when we should go for normally...
5,922
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
27
