Zone Reset
tlvaun
May 2002
Tennessee
38
Hello,
In one of my programs I need to reset 82 registers with one command, but cannot find a zrst instruction like in the fx series. I am using a Mitsubishi A1SCPU. Is there another way to go about this without using 82 seperate reset commands?
As far as I know, you are stuck with writing 82 resets.
Just checked the programming manual, there is no mention of any zone reset. You could get tricky and write some code that writes a zero to every coil, but I find that if you have your 82 resets at the top of your program, it gives you a starting point to check which outputs are on at any one time, which can be a valuable debugging tool.
Just remembered, you will have to break the outputs up, as there is a limit to the number of outputs per ladder line.
There is a way to do a zone reset but unfortunately, I neither have my book nor laptop with all my programs on.
I have wracked my brain for the instruction for an hour now but it wont come.
The 'A' cpu does not have a ZRST instruction (which is a big omission)and the programming manual does not tell you how to do it in any other fashion. But there is a way of doing it with one line.
I will get back to you with it.
Try to use FMOV
Go to www.meau.com, click on technical support and
choose A PLC. Download programming manuals such as
Fundamentals and Common Instructions.
Check out the FMOV instruction. You can clear 82 registers
starting at say D35 with "FMOV K0 D35 K82".
To clear 82 bits starting at say M35 use
"FMOV K0 K1M35 K21". Actually this will clear 84 bits
since 21*4=84. This should not be a problem since you have
much more memory than in FX plc.
have fun,
panic mode
Suppose you have a safety zone with as actuators in the zone : a failsafe pneumatic pressure release valve with safety feedback, drives on...
2,238
I want to reset a bunch of memories in my program and I was looking for a zonereset function but can't seem to find one. The FMOV function only...
2,280
Hello, using Ignition I want to automatically change the time zone for 30 Allen Bradley plc's at the same time, is there an efficient way to do...
464
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
993
Hello again! I have a new piece of equipment and there is a SafeZone Safety laser attached to both sides of the traversal unit (442L-SFZNMN A)...
752
