4 Position Selector Switch
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Water plant operator twisted the shaft off of this old 4 position selector switch that is mounted in a panel built as a bypass panel for a Danfoss VFD. I'd like to mail them a new identical switch so they can swap it out, but I need help identifying it in order to source a replacement.
If I cannot get an identical switch and need to substitute, then it would be useful to find a data sheet from this one so I don't have to spend too much time picking apart the wiring from this old panel without drawings to figure out which contacts are in which states in each of the four positions.
I was able to pop the contact blocks off the operator and use pliers to put the switch in the "DRIVE" position so the machinery is fine right now and they would only need to touch it if the VFD dies or something (knock on wood).
4 Position Selector Switch (Danfoss VFD Bypass Panel) (1).jpg 4 Position Selector Switch (Danfoss VFD Bypass Panel).jpg 4 Position Selector Switch (Danfoss VFD Bypass Panel) (3).jpg
Looks very similar in format to a Kraus & Naimer switch. I've never found a switch configuration that K&N couldn't sell me.
Thanks for all the tips. I will probably find a readily available replacement and go put it in myself to make sure it gets sorted out properly.
Hi all I am setting up a batch tank system, I have 1 pump which can pump to six different tanks(via pneumatic actuated valves). This is my first...
2,540
I am implementing a project using a Do-More PLC from AutomationDirect.com (Koyo manufactured) and one feature that we are tying to incorporate is...
2,898
I have to update a schematic to include a 4-position maintained selector switch. The contacts are isolated; there is no shared common as you see...
21
5,978
I am looking for a 4 position selector switch. MY google searches have only come up with minature rotary switches. What I am looking for is the...
3,371
i need to create a 3 position selector switch, Auto, Manual and Sanitation. Can someone layout the steps in creating this task? I saw a thread on...
522
