Dennis g
Hi Everyone I have a 1769-L33ER I am trying to get connected with 2 Powerflex 525 drives. I have the drives setup with IP addresses and can see them in RsLinx and under my module properties Drive Tab It says I'm connected in the upper right hand corner but at the bottom left the status says Faulted and I have the caution icons next to the drives in the I/O tree. Under the connection tab the fault says (Code 16#0110) connection request error. module not configured. Also there are three switches between the PLC and Drives The network has been tested as my wago I/O is working fine. Any help would be great. Thanks in advance Dennis
