PLC communication to ABB robots using ethernet
jyax82
Sep 2010
Ypsilanti, Mi
Has anyone used ethernetIP to communicate with an ABB robot? If so what hardware was required on the robot end. I have a Compactlogix PLC.
Yes I amusing a regular 6 axis robot. However the DSQC 699 card wont install into my robot, the controllers computer wont accept the DSQC 669. Can I use the regular LAN port instead? Thanks for the info.
Are you using an IRC5 controller??
Found that the DSQC 669 can only be used with the computer DSQC 639.
Maybe your computer is not compatible.
You CANNOT use the lan port, you need a special field bus adapter card in the IRC5.
Good Luck.
Yes it is an IRC5, I found the manual for the DSQC 669 and it will not install in my computer. Thanks for all your help, looks like we will be moving on to plan B.
Hello Everyone, I am using BMXP341000 Processor with communication module NOC0401 and programming software is Unity Pro S...
2,873
I do programming in GX developper for ABB drive model ACS 550 control via modbus communication in FXCPU PLC,I can read the Data of drive...
3,245
Hi everyone. I have a problem in my current project. I am using 4 ABB PLC PM-583 and plan to use Modbus to communicate and integrate them to my...
4,445
hi i want to know how can communicate between PLC S7 300 &ABB drive ACS800 using profibus to transfer alarm from drive to PLC?
2,900
Hi I hope someone can help me here. We have serial communication between siemens S7 400 and ABB AC450 using MVI card CI532v03. At times the...
3,150
