1734-aent/b eds
Plavyuk
Oct 2011
Dublin
I have a problem with the Point IO setup, module is not in the list ( EDS file is installed). When I run EDS installation tool/unregister I see the module is in the list.
I use RSlogix v20, 1768-L43S, 1734-AENT/B FW 4.3
Any ideas? :confused:
Does anyone know where I can get a version of this that supports firmware release 3? I need it for a machine that is being shipped from the US. The drawings say 1734-AENTR/B version 3 and the sample code I've been given has the point I-O as unrecognised devices. I've installed the 2 add-on profiles available from the Rockwell link but they are for version 4 and version 5 firmware.
Any help would be greatly appreciated.
Not to worry, I just rebooted to see if that worked and like magic all the modules & configurations are now visible. Thanks for the original tip in this thread.
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
738
Hi All, Have got a problem which i first thought to be a network problem but now starting to think we have got a broken 1734-AENT PointIO unit...
29
4,497
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,417
Hello, There is a small test rig in our work which is sometimes salvaged for parts. The test rig is connected to a small robot used for training...
1,644
I had a 1734-AENT point IO adapter go bad. It was a series A F/W 3.006 I order a replacement, however it was a 1734-AENT series A F/W 1.033 I...
2,074
