1734-aent
Thank you Ken . It is a long time since I used a SoftLogix simulator but I have a vague memory that external modules ( to the PC ) were handled by SoftLogix through RSLinx . From your reply , can I confirm this is no longer the case .
Paul
Once upon a time the real-time drivers that SoftLogix used had the trade name of "IOLinx". But as a product that never really took off.
On the side of the module to thright of the ethernet port . It may be printed as FW before the revision . On a seperate lable next to it is the MAC address , which you will need if you use Boot/P to set your ip address .
Because this is SoftLogix, I'm not sure how to find the revision of the controller.
It might appear as a ToolTip when you hover the pointer over the CPU in the virtual chassis manager, or you might have to use RSLinx and right-click on the CPU object.
Or you can open up Controller Properties in the RSLogix 5000 project.
I don't think that the SoftLogix chassis manager has a Help -> About menu item.
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
628
Hi All, Have got a problem which i first thought to be a network problem but now starting to think we have got a broken 1734-AENT PointIO unit...
29
4,493
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,412
Hello, There is a small test rig in our work which is sometimes salvaged for parts. The test rig is connected to a small robot used for training...
1,641
I had a 1734-AENT point IO adapter go bad. It was a series A F/W 3.006 I order a replacement, however it was a 1734-AENT series A F/W 1.033 I...
2,073
