1747-UIC Cable Requirement
Sep 2003
Philadelphia
75
I'm on my way to pick up a 1747-UIC converter. I have a question or two that I hope you guys can help me with. I ask here rather than at the counter because I don't want to appear stupid or cheap in person.
The manual I downloaded seems to indicate that the 1747-UIC will need a "1747-13" cable to connect to the SLC500 fixed controller (what I'm learning on) as well as the /01/02 and /03 modules we use at work.
That "cable" is listed on AB's website as "SPECIALTY MODULE TO ISOLATED LINK COUPLER CABLE " and sells for $58!
I thought I was going to be able to get away with a piece of CAT5 networking cable. Any chance of that happening? Or do I just bite the bullet and buy the cable?
Thank you for your time and help;
Frank
PS: I know I'm lucky to be able to buy this thing at all.
The 1747-C13 has high-quality connectors and shielded cable, but sheesh !
There's nothing magic about that cable; it's a straight-through RJ-45 cable pinned out thusly:
P1 COLOR FUNCTION P2
1 RED CH. B TX/RC 1 TOP
2 BLACK CH. A TX/RC 2
3 BROWN +24 VDC 3 **
4 WHITE SIGNAL GND 4
5 BLUE TX-EN 5
6 DRAIN EARTH GND 6 **
7 GREEN SIGNAL GND 7
8 ORANGE +24 VDC 8 BOTTOM
** pins 3 and 6 are not connected on the 1747-C13 but are on the -C10, C11, C20.
The other DH485 cables have a hard-to-find AMP connector on them and you usually have to buy them from A-B, but I'd say for your UIC go ahead and make up a good CAT5 cable on your own. Use the best connectors you can.... about 80% of the old DH485 cables around my shop have the latches broken off !
Thank you !!!
That is what I was hoping to hear. Thank you for responding. I talked to an AB technician and he was candid and helpful but did not have the info you provided.
He had a picture of the cable arrangements for connecting the 1747-UIC and he confirmed that it looked like a simple cable but could not say for sure what it was.
They did not have the 1747-C13 in stock anyway.
Thanks again for the help;
Frank
1747-UIC uses regular RJ45 on UIC side - it is not a special connector like PIC. So regular patch cable will work.
BTW, how much UIC (list)?
I should have said that I was talking to a "Rumsey Electric" representitive and not an Allen Bradley technician. I just had Allen Bradley on my mind.
I paid $202 and was happy.
Frank
I got quote $202.02 OEM price for 1747-UIC, local factory stock, 3 days delivery. I may get one to try.
Also I'll talk to plccables.com next week, they told me they will have USB to SLC for around $60 after Dec-15. Too bad it will not have opticall isolation...
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,301
I was surprised when I found that we had an old SCL 500 in the plant here I tried communicating with it via a 1747-UIC and a straight RJ45 cable...
2,593
Hi there, I been looking for a cheaper 1747 pic or 1747 uic when I saw this in ebay. Can you give opinion about the picture? thanks.
9,192
S
I would like to communicate to a Fixed i/0 SLC-500 using the 1747-UIC. Is it AB 1747-c13 cable is the only correct choice ? ( i.e RJ45 connection...
4,293
There could be a danger using a Cat 5 cable to connect the 1747-UIC to a SLC500 fixed version. I don’t know why , can’t see how, but I believe the...
20
49,334
