1756-HIST2G Historian ME
Bullzi
Jun 2012
Colorado
1,530
Just starting a new project. One of the modules spec'd is a 1756-HIST2G FactoryTalk Historian ME. Has anyone ever used this module before? Any advice on implementing it? There seems to be a minimum Firmware version but nothing that shows the max Firmware version. Since I was able to add it to my v21 project does that mean it will work with v21?
I have downloaded the Manual and I am looking at it but just want to start out on the right foot. Thanks for any advice you can give.
I wouldn't worry about it.
If Studio 5000 "took" the revision at hand you'll be fine.
Historian ME modules are totally different "creatures" than any other mainstream 1756 hardware.
Anyone any idea how to install the Historian Module into the controllogix rack configuration, using RSLogix 5000 Enterprise. Dont seem to be able...
1,812
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
74
372
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
162
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
146
