1771-ifc
Mar 2004
55
Does anyone have the block transfer setup/configuration for a 1771-IFC. I'm using a PLC5/40 for a CPU in a 1771 A1B rack. What should my slot config be? I've tried Generic Block transfer with 64 words but I still get an error. I'm not getting a fault LED on the IFC so I think that's okay.
Regards,
CTG
1771-IFC (same as 1771-IF) is not the same as 1771-IFE mentioned by Mickey and uses different setup.
1771-IFC is very old module from PLC2 times.
I have user manual in the office - will check monday, but I think it uses BTR of 8 words only
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
378
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
599
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
909
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
984
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,057
