525 UDFB in CCW
Thanks for the insight on using Global and Local variables. I have run into this type of strange behavior in another project that I had misused the Global and Local variables.
I have nothing to add to this except I have found the UDFBs to be shaky. I worked with the PIDE and PID ones as well as the one you referenced for CCW Micro 820 programming at there seems to be a lot of issues associated with it. I'm just messing around with the SCP block now and have been successful but have't quite found a CPT one as of it
Hi PLC Guy,
I had worked in a project with the Micro850 and Powerflex525 over ethernet. Looking for some sources I found the RA_PFx_ENET_STS_CMD block, however it has a weird behavior: althoug the block is enabled and I sent a speed reference and the START enabled,sometimes the powerflex track the reference but in other times it doesnt.
Could you send me your example code? please, so I can detect my mistake.
My e-mail: [email protected]
Iv sent you what you have asked for in a private email.
My email server is currently down but should be up soon and it will automatically send.
Sorry for the delayed response, Iv been out for a bit.
Sample Code
I am starting out going down this path with a micro820 and two powerflex525 drives.
I have the UDFB already and am wondering about the tags local vs global. This may be a stretch but would it be possible to get sample code? I find AB support also lacking along with any help items.
email: [email protected]
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
235
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
247
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
476
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
234
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
300
