90-30 help
wayned
Apr 2009
IN
Trying to upload the program from a 90 30 with a 363 cpu. I am not sure what software this was programmed with. Tried logic master version 9.05 and 9.06
but got this fault Load aborted plc contains files which are incompatible with this release. Has this probably been programmed with Versa Pro or Proficy maybe? Thanks
If it was programmed recently i would think, yes it was indeed programmed with something other than LM but you never know. What fault did you get specifically?
I had trouble loading a lm file into a 363 once and had to import it into versapro and it worked. I still have some seires one bricks and old cpu331s that I am replacing as I can to make them work with machine edition.
Is versapro free yet...
No.
However, with a Demo CD/DVD of either VersaPro or Proficy ME you will have four days of unrestricted use of all software.
Remember, VersaPro has not been updated in about 10 years. In software years that's a millennium.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
80
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
455
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
171
63
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
552
