A-B MSR22LM safety relay issue HELP!
neilgehrke
Sep 2010
napa, Ca.
26
I recently installed a new safety system and used a MSR22LM muting light curtain module. The setup consists of a light curtain, two muting eyes, and the unused channels are wired through guard door switches. Everything works as planned EXCEPT the override function. If I leave a pallet in the protected zone and let the relay time out for a muting fault. I am NOT able to press the reset button and override the relay to temporarily move the pallet out of the protected zone. I've read the manual a few times to make sure I had everything wired correctly. Any ideas what would cause this issue?
HELP?!
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
883
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
123
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
114
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
253
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
133
