AB 6180 & RSView...
K.C.
Guest
K
Hi All,
I have an AB 6180 Induatrial Computer running RSView. I am having problems making the display keys (hotkeys) work. I can get the "K1-K10" to work. They function the same as "F" function keys. I can't, however, get the "A,B,C..." keys to work. It says I have to use CTRL with them. I tried that and nothing... Any suggestions? Also does anyone know how to make the project run when RSView is started. I have RSView in the startup menu, but I was wondering if I can make it go ahead and start the project as well. Thanks for any help...
Can't answer your 6180 question, but for the RSView part make sure that the shortcut you use to start RSView calls your project. Here is an example:
"C:\Program Files\Rockwell Software\RSView\rsview32.exe" "C:\RSView Projects\cement line\cement.rsv" /r
The first part in quotes is the path to RSView32. The second part in quotes is the path to the project I want it to open. The /r tells it to run the project.
Create that shortcut and then if you want it to run on computer startup put that shorcut in your Startup folder.
good luck!
OG
systems
with some systems the hotkeys dont even work at all i heard it was a glitch in the progrm>>
Anybody know where I can get an 6189-fpabagp video driver card or equivlent. AB discontinued this type and can offer no spare due to thier...
2,775
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
308
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
258
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
812
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
797
