Adding M241 to unity pro 8.1
kalabdel
Feb 2015
Ontario
1,108
Hello gentlemen,
First time using Unity Pro XL and can't find M241 in the list of CPUs so I figured there must EDS, DTM or some other file/package with some other acronym that I need to add to the library.
Google hasn't been much help and neither is the manual as I have no clue what I'm looking for.
Kal
You can't program M241 with Unity, you need Somachine V4.2 for programming.
If you mean only to read/write values to M241, then look IO scanner or read/write_var blocks.
Thanks Lare. I guess I need Somachine V4.2 then.
Thanks a lot as always this forum is invaluable.
Cheers
Kal
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
299
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
100
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
171
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
132
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
215
