Adding M241 to unity pro 8.1
kalabdel
Feb 2015
Ontario
1,108
Hello gentlemen,
First time using Unity Pro XL and can't find M241 in the list of CPUs so I figured there must EDS, DTM or some other file/package with some other acronym that I need to add to the library.
Google hasn't been much help and neither is the manual as I have no clue what I'm looking for.
Kal
You can't program M241 with Unity, you need Somachine V4.2 for programming.
If you mean only to read/write values to M241, then look IO scanner or read/write_var blocks.
Thanks Lare. I guess I need Somachine V4.2 then.
Thanks a lot as always this forum is invaluable.
Cheers
Kal
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
60
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
138
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
174
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hi Folks. I am gearing up to add a 2nd identical HMI to a project. This 2nd HMI will basically be an exact clone of the 1st one. The equipment...
266
