Allen Bradley 172 - I OF2
Baggy
Mar 2015
Minnesota
I am looking for information on how to correctly wire a analog 1762 if2 of2. The manuals available do not give specific info and it is wired different than a regular analog module. I am using it with a AB 1100 for a class project.
How clear it is can be relative to the experience of the person looking at it.
The AB diagrams in this case can be a bit confusing.
You need to include specific details when you ask a technical question otherwise it wastes peoples time when they need to ask for things that should have been stated.
What type of sensor are you using?
What is the range of the sensors output?
Sorry for the lack of information. I am in the process of learning. I was looking for a voltage change 0-10 with the module connected to the 0-10 input on a VFD. I was using the input of the module to control the output to the drive, first attempt the voltage did not change, I disassembled and rebuilt the simple circuit and it worked as expected.
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
108
416
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
111
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
782
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
472
