Allen Bradley 842D Encoder Replacement
yam
Mar 2024
Dubai
Hi Everyone,
I replaced encoder 842D-60131331BXA with a new same part number. Dip switches and Preset Push button are considered.
When I tested, it rotated in reverse direction. When I pressed CW from HMI, it rotated CCW and vise versa.
Then I put back the original encoder following the same procedure. It worked correctly.
How can I correct the rotation direction of my new encoder?
Please advise. Thank you.
The CW/CCW direction of those encoders is programmable over the DeviceNet network. You will need to use RSNetworx for DeviceNet, or a message instruction from the logic controller, to change that parameter and save it to nonvolatile memory.
What model of controller and DeviceNet interface module are you using ? Do you have RSNetworx for DeviceNet software ?
Hi Ken,
For controller, 1769-L33ER and for the DeviceNet, 1769-SDN.
I am not sure if I have RSNetworx software since I'm only starting on using Allen Bradley.
I need to check on this and learn as much as I can.
Do you have any procedure that can help me to solve this issue. I'm also checking it now.
Thank you.
Hi Ken,
Thank you.
Currently, I don't have RSNetworx for Devicenet software installed.
How will I know which version do I need to install correctly?
Thank you.
367
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
93
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
623
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
441
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
