allen bradley coms port
jimmydbkr
Feb 2017
texas
I have a L32e Allen Bradly compact logic that keeps losing coms with panel view , I can reset the processor by removing the power, but its not completely fixing the problem .
any ideas????
Are you using the serial port to communicate or the Ethernet port?
A long time ago we used L31's and PanelView Plus over serial, the early v17 firmware would behave like this. After a day or so, the comms would drop and only a reboot would cure it. Maybe the L32E's would suffer from the same firmware bug. That's probably a long shot. If you happen to be using v17, I'd make sure that it is 17.7.
If it's over Ethernet, the first place I'd go to is the web page of the L32E. There are some really helpful statistics that you can look at to help diagnose issues. I haven't looked at a L32E's web page in quite a while but something like the diagnostic overview, look for missed and rejected packets, this should be zero. Ethernet Statistics will have a bunch more statistics like FSC, alignment errors, collisions and such, again a normal system they will be zero. The other thing that you have to watch out for over Ethernet is the number of connections. If the L32E is exceeding the number of connections, that could cause your L32E to stop communicating to your PanelView.
367
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
93
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
623
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
441
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
