Allen Bradley Programming Question
Ctrayler
Feb 2004
Guymon, OK
21
I am working on converting a program from Allen bradley to Concept, I ran across an item in the ladder logic-
-][---[AFI]---][-----
I don't know what the AFI portion of this run represents, any help here would be greatly appreciated.
Thanks,
Chris
This is an Always False Instruction. The suggested use is a temporary disable for a rung while testing or debuging. It may have been used to disable a portion which is no longer used.
I looked up the AFI instruction in Logix 5000 and it is an "always false". It makes the logic in the rung always false no matter the condition of the logic on the left of it. I guess that it is usually used in debugging a program. It does not show up in my RSLogix 500.
Thanks for the help, I believe that I understand the fact that if this is in the run, then that particular run is disabled. By the time I finish with this conversion, I think I may understand alot more about the allen bradley programming language. I thank everyone for their help as much of these terms I am not familiar with.
Thanks again
Chris
Just a little anally retentive remark.
CTRayler,
"it disables the rung" is not correct.
To use your terminology it would mean that OTE outputs in the rung would be remain in the last state when an AFI is inserted in the rung.
To rephrase your original sentence it would become "it disables the outputs in the rung, and ignores all other instructions".
smiller,
"it makes the logic in the rung allways false" is correct.
Point to be aware of: If there are OTE outputs in a rung, then they will be forced OFF after you have inserted the AFI. So the rung would still be active in a sense.
I'm looking for someone who is more experienced than to bail me out of this mental thought experiment. I am moving away from programmed alarming...
982
Hello guys, I was reading programming manual of Allen Bradley and they mentioned few tips and I want to clear one tip tip: I/O module data...
2,542
We have a trainer set up and I am trying to learn function block programming to reinforce my resume. In ladder I am pretty fast. I double click...
2,081
My company is about to adventure in to servo motion. I have never programmed them and I am just looking in to it. I am just looking for any tips...
12,826
We have used many AB VFDs, once installed, and under 480vc power, are commissioned via appropriate Drive Software, and network connectivity...
4,922
